Transmission/torque convertor/flywheel questions
Discussion in 'The Garage' started by big_truxx, Jan 29, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    When doing engine or tranny swaps, what determines what torque convertor you will need? Is it the engine? Will a 350 SBC need a different convertor than the 454? And the flexplate/flywheel is also engine specific right?
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    flexplate flywheel is engine type specific, internal or external balance
    Internal balance = most SBCs, 396, 427
    External balance = 400(sb), 454
  3. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    That's what I thought there. What about the convertors? Are they all the same or what?
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You should get a torque converter that matches what your needs are. My needs are a low stall converter for rockcrawling so I have a 1000RPM stall converter. As far as the converter being the same they should be. I helped do a SBC to BBC swap once and we didn't change the converter between engines.
    Harley
  5. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    Cool beans! Thanks bro! :waytogo:
    Another ? Is the 6.2 convertor the same as a gasser would be?
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the 6.2 converter externally is the same, but the stall speed is lower than a gas converter.
  7. dyeager535
    26,979
    It gets fairly complicated, but essentially, a "rated" stall speed converter will actually stall at a different RPM based on engine output, such as between a 350 and 454.
  8. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    So really I need to get the correct convertor for the engine I am running. I am just trying to figure out what is reusable in engine swaps. I have a 350/400 combo in one truck and it will be getting a 454 swapped in at some point. I was thinking it may be possible to reuse the convertor but I want to do it correctly and not have to make the mistake and have to take the convertor out and replace it. Making more work than is necessary.
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you need to get he converter for both the engine and tranny.
    match the converter up to the tranny and the stall speed to the engine.
    luckly the th400 and th350 converters are the same externally
  10. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    stock 350 speed is around 1800 i think
  11. dyeager535
    26,979
    Stock for what? GM used a different stall speed based on application...I know just for the '83+ G-bodies (monte carlo, regal, cutlass, etc) GM used no less than 3 converters for the 2004R.
    Truck converters were probably different based on engine, 2wd, GVW, etc.
  12. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    So I will most definately get a new convertor when I put the 454 under the hood of my 82. :waytogo:
  13. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    on my 88 4x4
