Transmission trouble.... 700r4
Discussion in '1982-Present GM Diesel' started by savagek5diesel, May 26, 2005.
  1. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    hey guys, the other night i was on my way home and on the freeyway my truck went to down-shift into 3rd and started revving out, it has done this to me a handful of times in the last couple months. usually i just pop off the gas pedal and it'll jump back into a gear. this time......... nothing. i was able to pull it into a gas station, but it was at a crawling speed and at a perty high rev. i checked the dipstick and it was a little low, but when i smelled the fluid on it, it smelled a bit like burnt rubber. my buddy stopped by to give me a second opinion and said i probably had a badly worn band.
    I read every 700r4 post and came to realize that there might be a couple simple things i'de be able to check to get my truck driving again without needing to go get a loan. It's my DD so it's very important that i get it going without breaking the bank.
    I was wondering if you guys would be able to post up what i could check for. I'm gonna be pulling the pan also so if there's anything to look for specifically while i'm in there please let me know. opinions on getting a junkyard tranny, buying a new/updated 700/ or a rebuild? the rebuild i would try to tackle myself so information on what specialty tools i need to get and the type of rebuild kit would be best suited for the 6.2.
    Thanks for any input guys!!
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    A full rebuild kit (about $100 from Transmission Exchange Co. in Portland oregon) and a rebuilt torque converter (about $200-300) are going to be the minimum to fix that tranny. There are no special tools required for the 700R4 that you can not build yourself. Basically they amount to a pair of small flat bars about 3/8 x 2 around 10-12" long. Drill a hole in the center of both of them and use a long bolt and nut to compress the springs enough to remove snap rings is all you need to do. I'd also suggest a good rebuild manual and plenty of work bench space to lay everything out in order.
