Transmission Vaccum issues
Discussion in 'The Garage' started by 79CK454, Jan 15, 2005.
  1. 79CK454
    79CK454 Registered Member
    Jan 15, 2005
    7
    Nebraska
    Hey...New here Just bought a 79 Chevy 1/2 short box from a buddy of mine. He sold it to me thinking that the tanny was out. After lookin it over found out there was a vaccum hose on the tranny with a hole in it. I replaced the line and the part? ($10 fix) great......
    Well started it up, let it warm up topped off the tranny fluid and took off. 1st, 2nd, and 3rd shifted like it was new. Drove it about 10 miles, put it back to the shop to tweek some minor crap (shocks, rims & tires).
    Took it out. Only get about a mile sounded like it shifted to low. Blue/white?smoke out the dual exhaust. Would hardly run. Cripple home, oil had water or tranny fluid in it? Is this a head gasket issue? Vaccum issue? Any ideas I have not dug into into it yet. Worried!!
    Really strange, cause like I say it was fine for 10-15 miles with the new vaccum and hose? Any help would be much appreciated!!:cool1:
  2. ryoken
    Jun 13, 2003
    29,624
    1,379
    Jersey Shore
    vacuum modulator... motors sucking up tranny fluid...
  3. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    modulator????
    I might be the tranny vacuum modulator --the rubber diaphram in it might have failed,allowing engine vacuum to suck ATF out of the tranny and burn it in the motor...but I doubt it would show up in the engine oil,that sounds more like head gasket failure--the oil will look milky or like mayonaise in the valve covers or on the dipstick if water got in the motor from bad head gaskets or cracks...
    Somtimes a brake master cylinder leaks into the power brake booster and the brake fluid gets inhaled and burns in the motor ,causing lots of white smoke--usually it only does it a few times before your brake light on the dash will come on,due to the empty resivoiur in the master cylinder,and you'll notice the brake pedal will almost go to the floor...:crazy:
    Good luck!
  4. 79CK454
    Jan 15, 2005
    7
    Nebraska
    The part I re-placed wast the Vaccum Modulator
    I did check the dip stick looked almost milky caramel color. When the vaccum fails would would I still have oil pressure? I did still have oil pressure? Where should I begin.....New vaccum line and modulator? Thanks for the input!
    Chad
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Check inside the vacuum hose on the modulator for transmission fluid. If it has fluid inside, change the modulator. As far as the water in the engine oil, I'd start checking for a blown head gasket. Good luck!
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If your oil looks like a chocolate milkshake you have water in it. = Bad head gasket cracked head.
  7. 79CK454
    Jan 15, 2005
    7
    Nebraska
    What would it look like if the motor sucked in tranny fluid from the modulator going bad.... Or is that even possible? Thanks
  8. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    The transmission fluid wouldn't get to the engine oil. It would be sucked into the intake manifold and would be burned with the fuel mixture. You'd notice a drop in the transmission fluid level and smoke out the exhaust pipe.
    It sounds like your main problem may be with the engine. You need to pinpoint the water and oil problem in the engine.
  9. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    take a sniff test
    If you bring it to a shop that does emission tests,they can tell you in a few seconds if your head gaskets are leaking by putting the probe they usually put up the tailpipe over the radiator cap opening with the cap off and engine running,any reading of hydrocarbons indicates a leak between the combustion chambers and water passages--could be cracks in head or block too....I've seen intake gaskets fail at the corners where they seal the water passages and leak into the lifter valley too--.
    I think I changed a set of head gaskets on one motor for nothing,when I saw the intake gasket was leaking--but I was 75 percent of the way there,so I just kept going,and changed them anyway--the motor ran great for about 3 weeks,then spun a bearing--probably due to being poisoned with prestone(anti-freeze eats bearing material after awhile!:blush: )...hope its not the case in your truck--I'd change the oil and run it,and see if it gets milky right away again--it might just be condensation from long storage that built up in the motor....:crazy:
