Transmission wont switch out of first gear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Piranha300, Oct 24, 2001.
  1. Piranha300
    Piranha300 Registered Member
    Jul 1, 2001
    45
    Nebraska
    What would cause this? How much $ to fix? Any input would be great. Thanks
  2. Dip Stick
    Dip Stick Registered Member
    Oct 14, 2001
    73
    Murdock, Florida
    What kind of transmission do you have? Not real sure on what could be the problem cause i dont know when GM went to the 4L60E.
    <font color=red> It's not what you drive, it's how you drive it</font color=red>
    1986 K20 & Lots of Rust
  3. Piranha300
    Jul 1, 2001
    45
    Nebraska
    Its on my friends 87 Silverado pickup. It looks to be the same as the tranny on my 91 k5.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My truck had a similar problem. It would only shift out of first if I floored it, and it wouldn't shift until I hit about 4K rpm's. (guessing, but very high). The first time I had my tranny rebuilt it cost $1100, and the second time it was $950. That is worst case scenario. That is a total rebuild w/R&amp;R. It could be something really easy, dirty valve body, screwed up linkage, etc.
    My Chevy isn't broken, its just out of gas.
  5. Jimmy84
    Jimmy84 Registered Member
    Sep 13, 2001
    18
    lafayette, la
    does it shift into reverse, neutral, park, and first? if so then its probably ur governor. it happen to my truck and cost me about 20 bucks to fix. just pull out ur governor and take it to a transmission shop and they should be able to put a new gear on it.good luck
  6. Dip Stick
    Oct 14, 2001
    73
    Murdock, Florida
    My truck is at the tranny shop now cause it wouldn't [censored] out of first after they just rebuilt it. And the tranny guys says my motor is knockin now so looks like i am in for some money huntin. im gonna go look at it tomarrow and see whats up.....probly is the governer....it shifted fine until i open it up all the way...well see
  7. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    something to check first would be your vaccum lines and modulator
    Brian
    <a target="_blank" href=http://www.saddletramps.com/BlazerK5.htm>www.saddletramps.com/BlazerK5.htm</a>
  8. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Governor or intermediate clutch (i think). My TH350 had no upshift because the governor flew apart. It wouldn't be a modulator because you have and overdrive transmission and they don't have one.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
