transmossion prob
Discussion in 'The Garage' started by 69K5, Jan 12, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    whenever i crank my car and put it in drive it dies. it works in reverse and park. 1 and 2 do the same as drive. if you keep the brake pressed and the gas revved it will stay running barely but kick and sputter like crazy. could it be the vaccum or the shift actuator?its a 90 taurus
    thanks
    nathan
  2. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    transmossion
    [/ QUOTE ] Maybe it is mad at you for mis-spelling its parts /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif
    ya it could be that, Id check that first.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    next time i'll put a disclaimer for spelling in there. how do you check one of those? besides put on a new one?
    nathan
  4. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i ferget,, id first make sure the rubber line isnt cracked or something. and make sure the line has NO fluid in it /forums/images/graemlins/wink.gif and that it isnt pooking into the intake manifold pressure , if it is, the exhaust will smell really sweet, like tranny fluid. and you need to put a vacume guage on it and see if its at spec, for each gear. i forget the spec though. it may be opening WIDE open and acting as a vacume leak.
    If that isnt it then your ecm may not be sending the right mixture / curve for being in gear at low rpm's.
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thanks
    nathan /forums/images/graemlins/rotfl.gif
