trany swap question
Discussion in 'The Garage' started by vw62rag, Mar 23, 2005.
  1. vw62rag
    vw62rag Registered Member
    Jan 1, 2004
    78
    topeka, KS
    hello, i have a 2wd truck with a 700r4 in it that blew up and im taking it out, and i have a good 2wd th400 trany and converter sitting here i wana put in, will this trany swap right in? is there any extra things i may be missing?
    thanks!!!!
  2. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    please someone help me, im under the truck doing this right now.
    please help
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you will have to redrill the frame for the crossmember, need a differnent driveshaft. the splines for the slip yoke are different.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no it will not work, but holes will be in frame rails for th400 position, as they came in 2wds as you well know
    you willl need a th400 driveshaft for the year make model and wheelbase youre putting it into
    truck 2wd th400 use a fixed yoke output,
    or at least 99% of them anyways
    not in the pre-73 trucks though
    good luck
  5. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    this is a 84 3/4 ton truck, i think someone put a 700r4 in it. and the th400 is out of a 84 3/4 suburban. the yoke coming out of the 400 trans has bolts and clamps on it, its not fixed. it looks like it may bolt right in? but i dunno. any other advice would be great
    thanks guys!
