Trany swap?
Discussion in 'The Garage' started by NoReGrEtS, Nov 30, 2005.
  1. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    I have a 81 k5 with 33000 1,2,3 hundred thou dont know it was given to me ya free, cant beat that, but it has 465 trany it needs a cluch but is it worth keeping? Im sure I can find a turbo 350 for almost as much as a cluch but what would it take to swap them out?and is it worth the change?I want to drive it drive it on trips and off round the piss out of it. I want to lift it 6in every one tells me to do 4in any problems between the two? I want 35s. what would you guys recamend?
    Shawn
    Trucks ,sex and no regrets :k5:
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    keep the 465... I'd rather have it than any th350.
    j
  3. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    I also would just keep the 465
  4. darenofears
    darenofears Registered Member
    Jan 25, 2005
    47
    Indiana
    sm465is very nearly indestructible doing almost anything
    Its worth keeping and a new clutch
  5. francis
    francis Registered Member
    Oct 11, 2005
    79
    kemp, texas
    it depends on what you want to do. if your crawling or mudding go auto but dont use a 350 use a 400 it's much stronger. to do the swap you need a flywheel, cooler lines, and a cooler, and i think you'll need a throttle pressure cable setup. the benefits of automatic vs std are you don't have to shift but like the other guy said the std is almost unditructible. but do what ever you want. i cant help it i'm biased toward automatics.
