  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    whats the best trany, a 350, 400 or a 700?????
    high
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    What are you going to use your truck for? How much do you have to spend? We need a bit more info..................
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    400 is stronger than a 350, but the 700 is kind of in a different catagory since it has an overdrive. More info would help though.
    '73 K5
    Chevy good...Ford bad
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    In stock form the 400 is by far the strongest (used behind Big Blocks mostly) but is the least efficient (not usually a big concern behind Big Blocks though), the 350 has a deeper first gear than the 400 but not as deep as the 700. The 700 is the weakest of the bunch. After a complete rebuild with updates, the local tranny guy says he can build a 350 stronger than built 400. This is of course using stronger input and output shafts. He said the case on the 400 is stronger but the internals have some drawbacks when used under extreme conditions. (Extreme being really big motors 500 CID+ and 44"+ tires, not your everyday combination). He also said the 700 can be built pretty stout (contrary to popular opinions), but it will not take as much abuse as a built 350 or built 400. Alot of your choice will be dictated by what you will use the rig for, what it will have for equipment (motor, tires, gears), and what you already have available for a tranny.
    If you didn't built it yourself, how can you call it yours.......?
  5. SummitXMK
    SummitXMK 1/2 ton status
    Jun 6, 2001
    141
    Idaho
    I have sort of the same question. I am thinking about putting a 700 in place of my 350 for the overdrive because I see a lot of freeway miles. Has anyone had experience with the durability of the Jet or B&M buildups of these. Or does anyone else build these up. I don't want to spend that kind of money if it won't hold up to my 400 when I do get out in the mud and snow.
    78K5 Cheyenne
