TRASFER CASE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Psycho, Mar 28, 2003.
  1. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    I have a NP208 Transfer case, how much fluid does it take, and do you use regualr GM transfluid for it???? let me know
    my T-Case is also emmitting a hum could it be too thin of fluid ? thanks
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    a 208 should be filled with ATF DexronII fluid. i am unsure of the amount, it is somewhere around 2-3 quarts, someone else problably knows for sure.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Dexron III ATF is the new standard. It will take 5 quarts.
    John [​IMG]
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Only 5 qtz? Man, it seemed like mine just used soooo much more than that. Like 10. I ususally fill it til it leaks out then I drive it and check it again to see if it wants more.
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    No I'm sure. I have this problem with too many trucks and engine and tranny swaps in them. /forums/images/graemlins/grin.gif
    I know for a fact its 5. /forums/images/graemlins/smile.gif Really
    John [​IMG]
  6. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    If you say so I believe you cousin. I think last time I used a half empty gallon container and didn't pay attention. But like I said, I just fill it til it pukes.
