trashed NP205
Discussion in 'The Garage' started by yoshisv, May 7, 2006.
  1. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    Has anyone ever broke a np205 case? today while wheeling at a local place called cedar forest i hit a mud hole kind of hard in 2 wheel drive, after exiting the hole and letting off the throttle i hear a loud pop and it quit pulling. i first thought the transfer case jumped into neutral, But when i grabed the t-case shifter it was just hanging there. I climbed under neath to find that the np205 was broke in half behind the crossmember:doah: . the only thing holding it up was the drive shafts. does anyone know what could have caused this?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Ummmmmmm.
  3. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    Is it the actual case that's broken or just the adapter?
    I've seen front driveshafts that were too long causing transfer case breakage because they'll bottom out.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I do believe I'd like to see a few pics of this...
    Along with the rest of the world.
  5. yoshisv
    Feb 19, 2006
    266
    It did not break untill i was out of the whole. It is the actual case not the adapter.
  6. 1977k5
    May 26, 2003
    9,995
    133
    In all seriousness, anything can be broken. Who knows, even if you don't have any binding issues and the transmission mounts are in good shape there may have been some casting issues or who knows what. I sheared a bearing journal off of the detroit in my old 12 bolt on the street. Anything can break at any time.
  7. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    You hit a land mine.
  8. yoshisv
    Feb 19, 2006
    266
    I will try to post pics in a day or two. The good thing is i have a spare np205. Is there suppose to be a brace of some sort that goes from the case to the tranny or motor? I know the stock drive line did, But the donor i got the sm465 and np205 out of did not.
  9. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I bet some of those bolts worked loose and it put just enough strain on your case housing to make it break. I find that I have to check those bolts on my 205 pretty often with hard wheeling.
  10. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    I have never seen a busted in half 205 but I got a core once where the idler shaft bore on the front of the case was egg shaped bad like a half of hole bigger.It came from a 1ton plow truck,after tearing it down to find NO oil in it I fiqured it would get hot and would expand/bind and just ate into the case.
    Let just say about the only salvagable parts from that case were the rubber plugs and shift rods!
    The NP-205 is a rugged transfer but not unbreakable,I wish I would have taken pictures of damaged 205 stuff over the years to add to Jasons collection!
    Gotta have some pictures of that please.
  11. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    I've broke a 27 sline input(th350) once. Sheared it at the O-ring groove.
  12. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Believe me, I'm intimately familiar with drivetrains getting broken. I worked for a while in a heavy-truck transmission shop - one of the tools on my workbench was a garden trowel, for scooping the shrapnel out of manual transmission housings. 1500+ ft/lbs of torque and 80,000+ lbs of resistance create quite a bit of mechanical carnage when they're not in harmony with each other...
    I know anything can be broken. There's a saying in the Corps: Give a Lance Corporal an anvil and send him out to the field for a week. The anvil's gonna come back broken.
  13. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    465/205 adaptors are pretty famous for cracking and breaking. I'd wager it's the adaptor itself and not the case of the 205. The adaptor is so much weaker it'd have to frag before the case even broke a sweat. I cracked a 465/205 adaptor in a mudhole once...got a nasty bounce at the end of the hole and the slightly long front driveshaft did the rest.:doah:
    Rene
  14. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yeah, I broke my 465/205 adapter bouncing on a hill climb. If the 205 case is broke, then I definitely NEED to see pictures.
  15. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Precisely my thoughts. Which is why I'd like to see pics.
    BTW; for anyone wondering, I'm not being confrontational on this. I'd just really like to see a pic or two...
  16. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have seen 1 broken 205 case. Stock truck, case looked like it exploded. It was full of oil too. I wish I had the camera that day.
  17. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    They break!..
    We grenaded a NP205 at the junkyard in a 68 K20 ,with an SM465 ..(the NP205 may or may not have been factory installed,it sure looked it!--had all the right brackets,etc..)...we were using the truck to try and pull the Trojan 1700 forkloader out of a mud hole with a flat tire!..
    --But the truck had been badly abused by us,the former owner who was a snowplow contractor,and probably 20 other people before we ever saw it..
    You'd be suprised how fast they shatter when those 30+ needle bearings fall into the case,and get wedged between the gears!..:doah: ...we had the 307 screaming at 5000 rpms in granny low,when there was an explosion--we both thought a rod came through the block,but the motor raced up,then idled perfectly---when I saw the rear driveshaft lying on the ground,with half the T-case still attached,and gears attached!--I knew it was the END for that truck!..:eek1: ..lucky for us we also had a 73 IHC 1-ton with a NP202 ? that succedded in moving the loader..we then used the loader to remove the remains of the K20..:rolleyes:
