TRE and DLE Interfering with each other and draglink contacting spring
Discussion in 'The Garage' started by MudFlap, Apr 13, 2004.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    I have crossover and Highsteer. I have the short, right hand thread 1 ton TREs on both ends of my draglink and Tierod. I have Sky Steering Arms. On the Passenger side arm the TREs on the tierod and draglink are in contact with each other rather badly.
    Has anyone else had this problem? And what did you do to solve it?
    I temporarily ground off part of the TREs that were touching each other, but I don't want to leave this as a permeanent fix.
    Also, when my passenger side of the axle drops and my springs "bow" upwards, the springs hit the draglink. I have made three draglinks, to try to remedy the problem and I ended up having to make the draglink straight on that end to keep it from hitting my spring, but it is playing havoc on my link ends. I have 6" TC EZ rides, and a tapered zero-rate and a 3" longer shackle. I know that the height of the zero-rate plus the taper is adding to my problem. Who else has had this problem and what did you do to fix it? Right know I am thinking about changing my shackle to 2" longer and putting less taper into the zero rate and possibly machining the zero-rate down to make it thinner. but I still don't know if it will be enough. I am just looking for some advise from someone that has gone through this before.
    Also just for comparison, how much clearance do yall with no zero rate and crossover have between your spring and draglink when the passenger side droops?
    Thanks,
    Trey
  2. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Anybody out there?
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    You arn't the first one to work around the zero-rate versus crossover draglink problem....I don't know what people do it to fix it besides changing one of the other...
    What brand of steering arms are you running ?
    Blake
  4. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Thanks for the reply. I am running Sky Arms.
    Does anybody have any input about the TREs hitting each other on the passenger side arm, I know that someone else has had this problem.
    Thanks,
    Trey
