TRE PART #'S
Discussion in 'The Garage' started by jackedjimmy, Dec 17, 2002.
  1. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    TRE PART #\'S
    I'm looking for a TRE with the large GM taper for a D60. It needs to be 3/4 inch threads, (one right hand and one left hand) with hopefully 1.5-3 inches of thread length.
    I got theses part#'s off rockstomper but it didnt say what they were for...ES2234R and ES2010L
    If these are the ones,are those numbers universal(can I get them at NAPA)
    If they aren't the ones...could someone give me the right numbers or a make/modle that mould have the same thing stock.
    I'm going to be making my own tierod and draglink out of shelby tubing soon and would need these prior.
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Re: TRE PART #\'S
    I don't know if these are the right numbers, but I got them from the Part #'s thread in the Bloody Knuckle forum...
    TRE's for the biggest "rod".
    ES2234R ---$24 in stock
    ES2010L ----$39 special order
  3. tjayandlisa
    tjayandlisa Registered Member
    Feb 14, 2002
    48
    Sacto CA
    Re: TRE PART #\'S
    tre part number es2234r(short chevy tie rod) and 2010L (short Dodge)is for the 7/8-18 thread not 3/4-16 that you said, you need the ES150R and ES150L but not sure if it will fit the d60 arm(you have),as most use the bigger taper
  4. jackedjimmy
    May 18, 2002
    195
    Redmond WA
    Re: TRE PART #\'S
    so both those are a 7/8-18 and one of them is left hand thread? Are those an aftemarket number or a Gm/dodge number?
    Thnks for the info
  5. tjayandlisa
    Feb 14, 2002
    48
    Sacto CA
    Re: TRE PART #\'S
    yes the L or R dictates Left or right and those part numbers can be used at napa,autozone,kragens etc. Go with the Moog brand, is best IMO
  6. jackedjimmy
    May 18, 2002
    195
    Redmond WA
    Re: TRE PART #\'S
    Anyone else?.....I'm looking for ends that with fit a D60 taper but with 3/4 treads. I know this is a case where bgger is better, but I already have left and right hand 3/4 taps.
    Thanks For the #'s TJANDLISA
