TRE to heim
Discussion in 'The Garage' started by sled_dog, Dec 8, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I just have to redrill the whole in my crossover arms to go to heim joint correct? TRE is tapered hole isn't it? I think I'm gonna use Heims on my Tie Rod cause I have easy access to them for replacements and can get them cheaper.
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    What size heims are you going to run?
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    haven't really looked into it yet, Have to compare bolt sizes and start seeing what my cousin has on hand in his race trailer.
  4. zcarczar
    Feb 10, 2002
    2,495
    See what you can run before you start drilling anything on your arms. Your probably going to want to run a hiem with at least a 3/4" shank with a 3/4" eye.
  5. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    the bigger the whole in the eye the weaker the heim.PSC suggests 3/4shank with 5/8 eye.
    Static load for 5/8"is 40,572 and 3/4 is 28,081.
    Check your arms out first you may not have to drill anything.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    well I have ORD arms setup for TREs.
  7. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I have that on my truck (heims for the TR) i went w/ Aurora 3/4-3/4 and it has held up so far. Just make sure you check them regularly. I have found the heims to be cheaper and if not the same quality, better at PolyPerformance. if you already have the TRE's in, the thread might be different, not sure though. ANd i just drilled out the knuckle, just make sure you go in as straight as possible if you have to do it w/ a hand drill. It would be better to take it to a machineshop and have it perfect.
  8. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    where are you guys gettin those heim joints from. im up in BC and cant seem to find any.
  9. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
