TRE's
Discussion in 'The Garage' started by TxK5Blazer, Jul 29, 2005.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I am looking to do crossover on my 82k5 and I have a set of jeep dana 44 flatops. My problem is that on those knuckles the tie rod loads from the top and chevy from the bottom. Will a 1" zero rate work or will I need to look for some type of flip insert to re do the taper on it....Jason
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    All D44 knuckles wether dodge, chevy, jeep all load the tie rod in fromn the top.
    Just get some zero rates and be done with it. If you try and taper the hole from the bottom it is going so be sloppy.
