TRE's
Discussion in 'The Garage' started by willyswanter, Feb 19, 2003.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    TRE\'s
    Ok, first of all, I am correct that the BIG tre's are part #'s ES2234R and ES2010L correct?
    Second, I have a 79 Ford style Dana 60 front, what will I have to do to the knuckles to make these fit? I assume I'll have to get a tapered reamer and ream them out... Anyone know what the taper of the reamer is and where to get it?
    Third, what is the thread on the TRE's that thread into the tie rod?
    Thanks in advance! /forums/images/graemlins/thumb.gif
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Re: TRE\'s
    Hey,
    You have the right part numbers and they are a 7/8's thread. Don't know on the axle though.
    Blake
  3. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Re: TRE\'s
    7/8" UNC or UNF?
    I'm trying to figure out all the stuff I need to make my new tie-rod before my redneck ram gets here...
    Thanks for the confirmation on the part #'s /forums/images/graemlins/thumb.gif
    Just need to know if the taper is 1.5 or 2" per foot...
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: TRE\'s
    I run those same TRE ob both my tie rod and drag link. They are 7/8"
    Dunno about the Ford d60.
    -- Mike
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Re: TRE\'s
    7/8"-18tpi, which is UNF
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: TRE\'s
    They are 7/8-18...but that is not a UNF thread (7/8-14 is UNF).
  7. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Re: TRE\'s
    So does anyone know if the taper is 1.5 or 2" a foot on the TRE's?
