Tricks for getting u joints out
Discussion in 'The Garage' started by protechk5, Mar 1, 2007.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Ok Ive done a million u joints before, but never the stock ones with the clips on outside of the caps. They are rusted as crap and the ends have already broken off. Anyone have any neat little tricks to get them out??
  2. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    i like to use a press and a socket...or just a bfh and a socket...
  3. protechk5
    Sep 26, 2004
    2,015
    VA
    what just break them out?
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    NO do not try beating on the U-joint until you have removed the clips or you will ruin the driveshaft. Carefully tap on the U-joint lightly to help loosen the clips then try removing the broken clips. Pry at them with a screw driver if you have to but DO NOT BEAT on the driveshaft.
  5. twoslo4five0
    Oct 5, 2006
    6,614
    71
    i was talking about after the clips were out...i usually use a screwdriver too and a pair of needlenose plyers...
  6. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    ball joint remover and installer, super fast and super easy way to work u-joints, removing and installing, rent it from Autozone,
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Does anyone ever read the question? :rolleyes:
  8. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    I would torch the center out of the U-joint, then hammer the caps towards the center until they are out. Then you should have plenty of room to get at the remaining part of the clip to get it out. Good luck.
  9. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I used a socket and ball pean hammer...the socket was squished by the time I was done...
  10. protechk5
    Sep 26, 2004
    2,015
    VA
    Yeah thats what i was thinking would be the easiest.
  11. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    victor wrench
