Trim removal
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Roostr84, May 9, 2001.
  1. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    I want to pull the exterior trim off of my 69 CST and some of it has screws, some has rivets and some has nothing. I was curious what was the easiest way to get the rivets out.
  2. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Most likely a drill, but since I have not done this I can't say for sure.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Sorry to steel your post but it is on the same topic. How do you remove the ones that have no "external" means of attachment (other than having them get ripped of by brush, which has happened to 2 on the right side)?
    '71 Blazer CST with alot of rust
  4. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I took one side off with the top when I foolishly tried remove the top by myself. I did the other side with brush like Triaged. Then I sanded the area around the holes, gave them a whack or two with a ball hammer and covered 'em with body filler and sanded to shape. No more trim to accidentally rip off and no holes to fill with water.
    That's because I'm the devil.
  5. Roostr84
    Aug 19, 2000
    451
    NJ
    Triaged...get outta my post, just kidding. I wanted to pull em opff and fill in the holes for a cleaner look.
  6. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Uh, that didn't answer my question. How did you take them off? I need to take them off before the rest of them get ripped off.
  7. Roostr84
    Aug 19, 2000
    451
    NJ
    Well I havent pulled em all yet... thats why i asked here. The ones that have no rivets or anything are just held on by clips like most trim back then. You can pull em off easily without damaging the trim. As for the rivets i am just gonna drill em out and fill the holes. Maybe this will help answer your question. I will let you know how it goes if you want.
  8. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Triaged, are you talking about emblems like the "8-350" emblems and the "K/5 Blazer" emblems? Those are held on by sheetmetal hat nuts from the inside. They can be removed by using a wrench to remove those nuts. The K/5 emblems require removing the wheel well liner and loosening the fender so you can access them from the back...
  9. Tonka
    Tonka Registered Member
    Jan 28, 2001
    30
    Fort Worth TX
    Kinda sounds like you might be talking about the trim pieces that run along the lower belt line all the way from front to back. They are held on by some funky spring loaded do-dads that are a real pain. First drill the rivets out. on the door trim, open the door and look for an acorn nut on a stud coming through the edge of the door where the skin is rolled over. When you get all these fasteners out of the way, the trim may be loose enough that you can spin it. If so it will likely pop off. If not then protect your paint and lightly pry the trim at each spring clip location. This will damage the clips but they are not reusable in most cases anyway. Hope this helps.
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Thanks for the help. That was what I was looking for. I will remove them before my next trip.
  11. olbluebeast
    olbluebeast Registered Member
    Mar 16, 2001
    16
    austin,tx
    just drill the center of the rivets. if you are careful on the emblems you can get behind them from the front with a putty knife and just break them off. then bondo the heck out of them and sando whamo, custom truck. it also llooks best when the stick on moulding is pulled off, and the billet alluminum piece on the rear gate between the taillights is taken away, although the holes from the clips here are a bit larger to fill..
  12. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I just lost one more piece of trim but this time to a rock. At this rate I might not have to take any of them off! 4 down and just a few more to go!
