Trimming for a Din style
Discussion in 'Audio' started by TheBlazerKid, May 20, 2000.
  1. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    Is it hard to cut the dash to fit a din style reciever from a shaft style. I am going to need to do this soon so any help will be appreciated
    Your right I dont understand the jeep thing!?
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Take the dash off. Trace the shape of your can on it and cut it out. Put the dash back on and by using a scratch awl, trace that opening on the metal. Take the dash back off. And now here is the trick: Instead of cutting the metal out completely, use something like a cutoff wheel and just make 4 horizontal cuts. On all 4 corners. Then just bend the left and right pieces of metal back out of the way. Put your dash back on and put the can in and bend the tabs down. If you want it to look nice, I usually use a 1/4 trim ring between the can and the dash.
    '73 K5
    Chevy good...Ford bad
  3. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Metra makes a dash kit that will help you cut thedash and comes with a trim peice that covers the rest of the area after you have cut it.
    89 w/DANA 60-Corp 14 w/5:13s n Detroit's. 4"lift 2" body. NEW AtlassII ordered 5-15-00. 38" sx's -
  4. TheBlazerKid
    Apr 26, 2000
    259
    Raymond, Washington
    metra huh, cool. you dont happen to know a phone number address e-mail or website do you?
  5. DBLAZER
    Apr 2, 2000
    1,716
    Haslet, Tx
    Any Compitenet stereo shop.
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Another option if you also need to upgrade/renovate your brushed aluminum dash inlay (IF you have the brushed aluminum) Cheyenne Pickup Parts sells a kit for $58.95 to replace all the old scratched brushed aluminum inlay. Used it on mine, looks great.
    '79 - 406 w/IROC TPI - K5#5 - a <font color=orange>sickness[​IMG] <font color=blue>you never get enough of!! [​IMG]
  7. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I pulled the stock out, placed the din where it was, drew the line and used an angle grinder to cut it out. It was easy and painless....
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  8. Nomorerust
    Nomorerust Registered Member
    Feb 18, 2000
    25
    Penna,US
    Just installed one last evening.If you have access to a dremel tool use it.I did and it turned out perfect.It's very simple.
