  1. 85 4x4 shortbed
    85 4x4 shortbed Registered Member
    Apr 7, 2003
    20
    How much do you have to trim if you go to 33x12.5x15s on a 8"rim on a stock truck?Will te rear be OK? Anyone have this setup?
  2. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    i got some on a 15 inch rim.. 33x12.5x15's and no rubbing here.. i trimmed a little off the inside front fender but you can't even see it unless you really look hard.. the back is fine, no worries unless you plan on goin 35's but then you fronts will rub alot too with no lift..
  3. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    I was just fine with my 33 12.5's until last weekend when we hit soft dirt at 35 mph and stuffed the right front into the dirt bank on the side of the road. Pushed the tire back into the body. Other than that everything has been just fine.
