triple gauge install question
Discussion in 'The Garage' started by divorced, Dec 26, 2004.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    triple gauge install question *updated w/pics*
    Pics are now at the bottom of this page. Muddytazz also posted a pic of his tranny temp gauge.
    I am installing a cheap mechanical Summit triple gauge set in my '79 K20. I put them where the factory gauges were and they look cool (like you care, right? :rolleyes: ) Anyway, the directions that came with them are of little help. I will try to find the wire in the wiring harness that went to the factory volt gauge, but if I can't find it then where should I connect the B+ wire? And if there is a bunch of air in the plastic tubing for the oil pressure gauge will this affect the reading?
  2. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    You can hook the voltmeter up to any 12volt source, tap in anywhere, it just monitors how much voltage you have at that point. And good luck with the plastic tubing. It has given me a hot foot before when it broke under the dash, and if you kink it , it WILL leak. I think the manufacturers advise against it but I use 1/8 copper line. I slide it though some old fuel line or vacuum line to protect it at wear points, and to avoid any shorts if you get close to anypositive wires.
    good luck
    bob
  3. diesel4me
    Jul 24, 2003
    17,545
    936
    Massachussetts
    I had an oil slick too....
    Ditto on the plastic tubing--ditch it and get 1/8 copper tubing,or you can use adapters to use 3/16 brake line instead,and using the rubber hose is a good idea too..and the air trapped in the line is normal,wont affect the readings...
    I put a triple gauge setup in a 75 K5 I had,I mounted them in the dash,where an A/C duct normally would have been if it had A/C,right above the ashtray--they looked great,and were easy to read there!--my K20 has a CB mounted in the same spot,real handy and it looks custom too..:crazy:
  4. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Got any pics of the gauges in the factory dash? I was going to do the same thing.
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    just make sure you tap your volt gage to a source that is controlled by your ignition switch.
    you could tap into the momentary power on your radio.
  6. divorced
    Jul 20, 2004
    5,115
    I don't have any pics yet. I will take some though and send them to ya'.
  7. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    Load up some pictures after you are done with the clusters, i'd enjoy seeing them.
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    On a side note but somewhat on topic, I installed a tranny temp gauge in the factory clock location. Turned out pretty slick :cool1:
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    got a pic??
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Not the best pic, I can get a better one if you'd like tho
  11. divorced
    Jul 20, 2004
    5,115
    That looks cool how you did it by putting it behind the factory plastic like the other gauges. I did mine the easy way and flush mounted them in the factory locations, but it looks good enough for my old pile. :D
  12. divorced
    Jul 20, 2004
    5,115
    Here are a couple pics of my elcheapo Summit 270 degree sweep gauges. They aren't centered perfectly because of the way the dash bezel is made, but it's good enough for me. Note my incredible oil pressure? That's at an idle at 1000 rpm!
  13. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    Did the same here and got rid of those garbage stock gauges and replaced with auto gauge
  14. diesel4me
    Jul 24, 2003
    17,545
    936
    Massachussetts
    oil pressure ok
    The 400 SB in my 74 K20(actually a 78 motor from a burb)has had no more than 8-12 lbs of oil pressure at idle for 15 years now--it runs quiet,no lifter noise or tapping when first started--many chevy motors dont have much pressure at idle-
    -I was suprised to see the 305 I put in my 79 C10 has 30- 35lbs at idle,and buries it past 60psi at 2500 rpm--I did put a new oil pump and screen in it,and a timing chain when I put the motor in--but it had the same pressure with the original pump (113,000 miles)and half clogged screen(full of nylon cam gear teeth!)as the new one!--maybe that motor is "tighter" than the 400,or more likely,the 400's oil pump is pretty worn,and I would not doubt if it has a screen clogged with nylon teeth too:blush: .
    I see you overfilled the gas tank!!(actually,you probably have a broken wire to the sending unit,or ground wire from the sender to the frame,or a bad sending unit in the tank)...I've had a dozen or so GM cars and trucks,and only 5 or 6 had a working gas gauge!:mad: .The gauges look good in the dash,and are much easier to read than the originals(at least they have bulbs that are brighter than candles!). :crazy:
  15. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    it's the gauge the stock one's are not very good, Mine did the same thing so I put the new gauges and now I have around 30lbs at idle, and it was never running as hot as I thought, and it is charging at around 13.6volts. the stock gauges were way off.
  16. divorced
    Jul 20, 2004
    5,115
    I wish that my motor was quiet, it makes a lot of knocking noise - warm or cold. I have a 454 at the machine shop so hopefully the sb will last. And yep, it's a missing wire on the fuel gauge. I had to remove it when I was putting in my divorced t-case and haven't gotten off my lazy a$$ to fix it yet... maybe one of these I'll get around to it... :rolleyes:
