Triple stick heim joint -- shortening okay?
Discussion in 'OffRoad Design' started by dremu, Jun 22, 2005.
  1. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    The threaded rod for my front output is 'bout an inch too long (I wanna say it was 5.25"ish?) ... the rightmost level couldn't go far enough back to engage front hi.
    I know it's only threaded rod, but I donno if my local hardware place carries fine thread ... so I'm hoping that individual transfer cases vary and slight adjustments (cough) are okay.
    -- A
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It's a little strange that it's off by that much but it is easy to fix, you can "adjust" it shorter all you want. We've had pretty good luck finding fine all thread at parts stores when we've had to buy it locally.
    Do all the other links hook up and work right? If it was a wrong version or had a spacer you didn't use they would all be off, that would raise a flag that something else is wrong.
  3. dremu
    Feb 27, 2000
    15,958
    452
    Nah, everything else went together fine; I am sooo glad you taped the bolts where they were supposed to be, as there's a LOT of hardware there :D (You need to hire somebody to do manuals for you, hint hint :) )
    It's entirely possible that the '205 was rebuilt somehow different (Cam! :) ), but it has three positions like it should, so I'll give it a roll.
    Thanks!
    -- A
