trouble code
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gill, Aug 21, 2001.
  1. gill
    gill Registered Member
    Aug 3, 2001
    37
    memphis and murfreesboro, tn
    Well I have got another problem actually its a repeating problem. Im getting a code 22 which means low voltage to the TPS. I had this problem before but I adjusted my timing and the problem went away, I havent been able to check my timing because I am in away at school and no timing light, but I kind of dont think that, that is the problem any suggestions would help me alot. Oh and I tried adjusting the TPS but that didnt help any.
    Mike
    88 College K5
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Disconnect your battery for 5 min. Let the engine cool off. Reconnect and drive around till the engine warms up. Recheck the code.
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Yeah, what fr8train said. You might also want to verify the wiring isn't shorting somewhere on the way to the TPS, or that no connectors are loose. It's a PITA, but try to trace back to the firewall from the TPS, and make sure there's nothin funky along the way...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
  4. gill
    Aug 3, 2001
    37
    I will try to disconnect my battery but what is that suppose to do besides clear the code. Do you think that it may be an ECM problem? I have traced my wires back to the fire wall and checked the connector on the ECM and on the TPS itself and that was a PITA but it didnt look like there was anything wrong.
    Mike
    88 College K5
