Trouble codes and rotten egg smell from exhaust
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by EZdoesit, Jun 11, 2002.
  1. EZdoesit
    EZdoesit Registered Member
    Oct 11, 2001
    33
    Minnesota
    Well for about the last week the check engine light has been coming on in my 87 blazer, it is a 305 TBI. It only comes on when I am cruising down the freeway for about 10-15 minutes and sometimes I can smell a really nasty sulfuric rotten-egg smell from the exhaust. I stuck a paperclip in the diagnostic port to flash the codes when I got to work this morning and I got a 12 and a 32.
    Any ideas about what it could be? I went to an online trouble code library and
    code 12 is no signal to ECM
    code 32 is EGR
  2. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    i'm no expert but i would replace the EGR.
  3. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    The nasty "egg" smell usually means that your catalytic converter has bit the dust.
  4. EZdoesit
    Oct 11, 2001
    33
    Minnesota
    Ok cool, we have no emmission testing in MN so I'll just remove my cat, I'll have to find out if there is some way to test the EGR to see if it is bad for sure, or maybe just disconnect it
  5. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Code 12 is a handshake code, NOT a trouble code...
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    This is probably not related to your problem, but a rotten egg smell is also an indication of the battery overcharging...
  7. EZdoesit
    Oct 11, 2001
    33
    Minnesota
    Battery is fine, 14 volts at idle
  8. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Ok... mine did the same thing. Except I had a code 43. At first it seemed like the check engine light would only come on during highway use but I found it just waited for the engine to warm up. Do you hear any real bad pinging before the light comes on? The fix for me was to replace the knock sensor. The engine would warm up, then ping, then the check engine light came on followed by the hideous smell.
    Just a thought.
  9. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Code 12 also means no distributor reference signal.
    I had a code 32 and it was the EGR vavle. The diapragm in the EGR valve should move up and down, so if it sticks you need a new one. A new EGR is $70 usually. After I replaced mine I found a good one in my TPI parts pile /forums/images/icons/tongue.gif so if you need an EGR let me know. </font color>
  10. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    You are correct...
    ...I meant that it USUALLY isn't a trouble code. Damn GM!
    /forums/images/icons/smile.gif
