trouble getting steering arm off
Discussion in 'The Garage' started by chrisb420, Nov 20, 2004.
  1. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    i am having trouble getting my steering arm to come off of my 86 k5 i unbolted the three nuts on top and took off the drag link and i cant get the thing off i have used the BFH and i just cant get it off any ideas /forums/images/graemlins/confused.gif
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Hit it harder.
    Your BFH isn't FB enough.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Hit the steering arm on the part number that is cast into it. Hit it all over really hard. Hit it from underneith also. If that doesn't work then get a bigger hammer.
    Harley
  4. chrisb420
    Aug 6, 2004
    652
    Binghamton, NY
    alright thanks for the info i will try to beat the hell out of it in the morning and see if it pops loose also anybody reccomend where to get new drag links the old ones are looking pretty sloppy
  5. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    I bought mine at NAPA. Maybe try some heat on the arm /forums/images/graemlins/dunno.gif
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Don't use heat unless you enjoy replacing ball joint boots. How do you have the axle supported?
  7. chrisb420
    Aug 6, 2004
    652
    Binghamton, NY
    i have the frame and axle on jackstands and i have tried everything. it looks as if after 18 years of new york winters have rusted the steering arm to the axle and it just dosent want to come off
  8. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    hit downwards and carefully use a chisel to try and remove the cone washers
  9. divorced
    Jul 20, 2004
    5,115
    Maybe you swing the hammer like a girl? /forums/images/graemlins/blush.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif JUST KIDDING! The steering arm is close to the last thing that I do when lifting a truck. I put the passenger side tire on and have all of the weight of the truck supported on it and a jack positioned under the driver side u-bolts (no jackstands under the frame). I feel that it is easier when the axle is supported like this so that the force from your hammer can apply pressure to the arm/knuckle connection rather than having it's energy absorbed by a loosly supported axle. Apply force through the entire hammer swing, not just enough to get the hammer moving. Watch the three cone washers(the things under the 3 nuts that you took off), when they look loose you can use a vice grips or channel locks to remove them, it helps to use a twisting motion as you pull up as if you were removing a nut. I took the arm off of my buddies 1984 K5 a few days ago; it only took 8 hits with no PB Blaster or other penetrant and we live in the glorious rust belt also. No, I'm not a monster or a brute, I'm a little scrawny a$$ that weighs in at 132 pounds (I could be the poster boy for the stick people), so I know you can do it. Keep swingin' /forums/images/graemlins/thumb.gif
  10. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I read a post from someone that said to just loosen up the nuts a bit and take it for quick spin /forums/images/graemlins/thumb.gif
  11. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Hit the steering arm with a BFH right were the numbers are stamped on the arm...2 really good hits and mine popped right off /forums/images/graemlins/thumb.gif
