Trouble installing the Torque Converter
Discussion in 'The Garage' started by ZZ4x4, Sep 2, 2005.
  1. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I have a TH350 which I recently bought, and the torque converter was not installed when I picked it up. I can NOT get the torque converter to go onto the tranny. :crazy: Usually you just rotate the thing until it clunks a couple times and slides on. This one, I wiggle and rotate and wiggle and rotate. It slowly goes further and further in but will stop with about 1/2 inch left to go. Any body see this before? Wondering if something is bent or galled in the TC because I can't see any problems in the tranny side.
    Any idears??
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Are you sure you got the right TC?
    Adam
  3. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    The seller told me it came off this trans, and they were the only trans & TC he had in his garage, but I am kinda wondering the same thing. :confused: However, the spline count looks right, and it seems to be a pretty normal looking GM converter.
  4. dyeager535
    26,979
    You aren't trying to mix TH350C parts with TH350 are you??
  5. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    the last one is the pump right? have to move it without moving the pump part-like the dist and oil pump. if u set it on there the weight and pressure of it will make it turn and not line up. have to treat it like a virgin when sliddin it on.
  6. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Ok, I'll try the gentle approach and see how she goes ;) .
    dyeager, I don't think the trans is a TH350C since there is no lock-up connector on the side. Not sure how to tell if the converter is the lockup style. I know they are the same size on the outside but the lockup one has a clutch on the inside. Any way to tell visually?
  7. dyeager535
    26,979
    No idea how to tell a lockup converter from non-lockup.
    Although it may not work correctly, I'd expect a lockup converter to fit either trans, as the input shaft (tip) is what's longer on a TCC tranny.
  8. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Well, looks like the gentle approach works. I bought her a beer to get her loosened up....OK so it was me who had the beer :rolleyes: ...but I gave it another try. The key was to stand the trans on its end. I hoped not to do this since the fluid pours out, but I think the play in the converter stator made the inner splined hub keep dropping down as I rotated it. When it was laid horizontal the inner splines must have stayed lined up and it finally dropped into place. Thanks for the suggestions.
    Jeff
  9. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    I learned the same lesson when attempting to install the torque converter on the tranny after sliding the tranny under the truck.......!@!#$%&*
    Eventually pulled it back out and stood it up on the tailshaft VERY gently then easily installed the converter and used a wrench with the box end bolted thru 1 of the bellhousing bolts to hold the converter in place while navigating the tranny back int the vehicle assy building (VAB)....
    Glad to see ya got her in :bow:
  10. diesel4me
    Jul 24, 2003
    17,559
    940
    Massachussetts
    Tcc...
    A tourque converter for a lock up tranny looks much "flatter" on the side facing the flexplate than a non lockup one,which is "rounded" on both sides..the lockup converter has a clutch disc inside similar to a manual tranny one,and it needs a flat friction surface to drive on inside the converter..
    In case anyone needs to know.. :crazy: :p:
