Trouble removing hublocks
Discussion in 'The Garage' started by steedalx, May 19, 2004.
  1. steedalx
    steedalx 1/2 ton status
    Dec 19, 2003
    142
    Chattanooga, TN
    I was having trouble with my left hub not locking so I got a set of Warn Hubs. The right side went on fine with no problem. The left one (the one that was bad to start with) will not come out. I got the cap assembly and both the lock ring and retaining ring removed but the body assembly will not come out. Any suggestions?
  2. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    thread in the screws that normally hold the cap on and try to pull it out wiggling from side to side. if that doesn't work you can try smaller screw drivers in between the hub and the lock and try to pry it out a little at a time from either side.
    maybe the hub is bent?
    good luck.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    squirt a little WD or something around the edge of the locking hub body. Old grease gets hard or you may have a little rust in there, and like mentioned screw in two of the allen boltsand try and wigle it out. Careful not to break off the allen bolts. /forums/images/graemlins/waytogo.gif
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    i had the same problem with my right hub, it wasn't locking so i converted to warn hubs. Its a bitch to get out get some carb cleaner and spray out the entire assembly And see if anything is blocking it. If your hub wasn't working this is the most likely cause.
  5. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Another thing that can make a hub difficult to remove is the snap ring groove on the end of the shaft.
    I have seen them devolop a ridge and have to be filed a bit for the hub to slide over the shaft.
