Trouble shifting 205
Discussion in 'The Garage' started by mo, Aug 29, 2006.
  1. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    i did some searching, didn't really find what i was looking for...
    I am having trouble shifting my 205 out of 4L and N. I can shift between those two but can't get down to 2H or 4H. If i loosen the bolts that hold the spring and that little ball down, sometimes I can shift it with the shifter, sometimes i can't. I can shift it by prying on the little bar there that connects the two rails (when the bolts are loose). Usually have to pry closer towards the shorter rail in order for it to move. The truck doesn't move again just yet, but I was having trouble shifting it even when the t-case was down.
    Any ideas on what would cause it, maybe the rails are messed up? Can i pull them without taking the case down?
    oh yeah, nothing that i can see is hitting the body or anything like that...
    thanks
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Sometimes they can be tricky. I have one and almost have to kick the shifter it seems to switch gears. Another is so smooth havta wonder if it's doing anything. Could have some burs or crud on the shiftrails, maybe pull them and clean 'em, then while your at it, do the twin stick mods.
  3. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    yeah, It's gonna be a pain in the a$$ if I gotta get out and shift it from underneath too many times, but what the hell, only need 4 low anyways :)
