trouble shifting NP241 from neutral
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by driney, May 24, 2002.
  1. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    I have a 700-R4 that seems to keep spinning the output shaft when in neutral if the transfer case is in neutral. Consequently, I have to shut off the engine to shift from high to low or back. Any easy fixes?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Don't shift to neutral. /forums/images/icons/wink.gif Seriously, an auto tranny will spin the output shaft if there's no drag on it, even when the tranny is in neutral. You need to learn to shift the t-case quickly past neutral to move between high and low ranges. Once you've stopped in the neutral position you either have to shut it off or grind some gears. /forums/images/icons/shocked.gif Oh yeah, you've probably already learned not to shift the trans into park while it's spinning free. /forums/images/icons/wink.gif
  3. driney
    Jul 6, 2001
    699
    7
    I learned about not using park with my 78 K10. Interesting sound!! With the TH350/NP203 I had in that truck, the only time I had this problem was at -10 or colder. I have found i can shift fairly quickly and get past neutral but not without some grinding. I thought maybe that wasn't normal.
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I've found that it's usually easier to shift between ranges if the truck is just slightly rolling, rather that sitting still. /forums/images/icons/cool.gif
