Trouble shifting t-case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HD, Dec 19, 2003.
  1. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    I’m having trouble shifting my NP203 t-case into low range. I can shift to all of high range and neutral, but no low range. Can someone help me out? Thanks! /forums/images/graemlins/k5.gif
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    what gear do u have it in. For me to get into 4 low I have to put it in park.
    Nick
  3. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Have you tried putting transmission in neutral?
  4. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    I have tried both and sometimes it will shift and sometimes not.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Get underneath and check the linkage adjustment /forums/images/graemlins/thumb.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    some of you are talking about a different T-case than what he has.
    a position labeled 4lo, for instance, does not exist in a 203
    if your truck is body lifted then you might have the shifter hitting the floor tunnel pan edge,
    i would check that also
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
  8. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    The next time that I have time to work on it I will check the linkage. I think my Haynes book has something about that. Oh I don't have a body lift. Thanks for the help /forums/images/graemlins/thumb.gif
  9. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I would think its the linkage. I saw the linkage on one truck get wedged against something on the transmission, and it wouldnt shift into any gear. We had to pry it out with a big metal bar.
    -Harrison
  10. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    I cleaned up the linkage a little and sprayed some WD-40 on it and it work great. /forums/images/graemlins/smile.gif
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Glad to hear its working for ya /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
