trouble tightening the rockers
Discussion in 'The Garage' started by shupach, Feb 20, 2003.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    i was following the chart i have and did 1/2 turn past zero lash but when the valve goes down, the rockers are really loose, should i tighten em down some more or is there a torque rating they should be at? i went ahead and tightened some down cause they were way too loose.
    thanks,
    phill
  2. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    what chart did you follow?
  3. shupach
    Dec 28, 2000
    648
    Dallas, TX
    i have one in this book that details a rebuild for a SBC, basically it was like TDC piston 8 exhaust, 45 degrees the next piston etc
    could it be due the fact my cam has more lift than usual?
    (.480/.498)
    phill
  4. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    did you put a new cam in or something
  5. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    I always go one full turn pass zero, remember the distance between the threads on the stud is very short a full turn pass zero still leaves the plunger towards the top of the lifter and ensures no clacking, off subject but last rockers I saw adjusted by a friend, not myself, the studs started to pull out of the head,I've never seen that before,then when he pulled out the stud and started tapping it for screw ins the tap broke off, he ended up throwing the heads away /forums/images/graemlins/crazy.gif
  6. shupach
    Dec 28, 2000
    648
    Dallas, TX
    ya comp cams 4x4 cam .480/.498 lift around 270/278 duration
    phill
  7. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    ok then sounds like your ok keep going till there tight start it and see what you got
