Trouble with my 1987 Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sicuro, Nov 2, 2001.
  1. sicuro
    sicuro Registered Member
    Nov 2, 2001
    5
    i just recently purchased a 1987 k5,, and it run's awful when it's first started up ,, then it warms up and run's a little better ,but going up hills is like a effort, i thought it was a carburator problem, but it seem's to be working,,then when i'm on the highway at about 65 or so the yellow service engine soon light comes on, for about 10 min, or more, run's like it's struggling, when on the gas, if anyone has any helpful hint's it would be greatly appreciated,, Thank you !!!!
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Fill in your profile so that people here can help... if no one knows anything about your truck, they will not be able to help.
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Not the carb since you don't have a carb, it's TBI. Pick yourself a Haynes manual, take a paperclip and stick the two ends into the top two right hand side holes of the aldl hookup that's right under the steering wheel and to the left, looks like a computer hookup. The check engine light will flash a code, like one flash, pause, then three flashes. Does this three times. This will be a code 13, but of course you might have another trouble code. Then look up in your Haynes manual or post it on here and we can give you more help.
    Bubba Ray Boudreaux,
    "It wastes drinking time."<a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
  4. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Buy a Chiltons or Haynes manuel at any parts store. You can use a wire jumper to check the ECM codes. It makes the engine light flash a certain number of times for different codes. For example a code 21 will have 2 flashes folloed by a pause and then 1 flash. You can cross refrence the code that the service engine soon light flashes with the code in the Chiltons or Haynes book to figure out what the problem is. If you get the book it explains exactly where to put the wire jumper and all that stuff.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It probably wouldn't hurt to change out your fuel filter...sounds kinda' like a fuel delivery problem to me.
    Another thing to check would be the spray pattern on your injectors. Pop off the air cleaener and watch how the fuel is shot into your intake. Make sure the fuel is coming out of the injectors evenly. If not, you may have to have your injectors cleaned.
    Good luck, bro'!!![​IMG]
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
