trouble with seat
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big Red, Jun 25, 2003.
  1. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    isn't the back seat in a second gen blazer supposed to lift off the hinges? /forums/images/graemlins/thinking.gif or do i really hafto unbolt them? cus i can get the passenger side off no problem, the driver side i fear is rusted tight. /forums/images/graemlins/angryfire.gif any suggestions would be helpful. /forums/images/graemlins/thumb.gif
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Your supposed to be able to pull that lever at the back and it releases two latches in the floor that the seat goes into. The seat then folds up against the back of the front seats.
  3. Big Red
    Jan 9, 2003
    250
    Bristol, CT
    i got that part down, now i wanna take it out.
  4. K5Blazed
    K5Blazed Registered Member
    Mar 16, 2003
    28
    Davis, CA
    you gotta unbolt the two hinges where the seat pivots. there is only one bolt in each. good luck.
  5. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Put some "deep creep" or "pb blaster" on it, let itsit for a little then use a breaker bar. Thats what I had to do wiht mine to get em off.
  6. Big Red
    Jan 9, 2003
    250
    Bristol, CT
    k, thanks. /forums/images/graemlins/thumb.gif
  7. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Oh, sorry I just misunderstood ya. As the rest of em said its just one bolt on each hinge. Spray some Blaster on there and theyll come on out.
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    those bolts are beefy, but a bunch of liquid wrench or wd40 and a 3' cheater bar will pop em right off... if that doesnt work, try a 6' cheater. /forums/images/graemlins/grin.gif Way i figure, I can put enough force on a bolt with a good cheater bar that either the bolt WILL come loose or the head will snap off... either way, its comin out!!! /forums/images/graemlins/thumb.gif
    j
  9. Big Red
    Jan 9, 2003
    250
    Bristol, CT
    kewl thanks ya'll. /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif
