Trouble?
Discussion in 'The Garage' started by 82_k5, Jan 29, 2005.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    I just got my 700r4 back from the shop, they were replacing the second gear band, and the tail shaft?? the one that comes out of the back, has a little bit of play forward and backward but none up and down or side to side. Is that normal? I don't want to put it back in just to have to take it back out again. Thanks
  2. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Look into the slip yoke eliminator kit (SYE). You will love it if you ever have a failed driveshaft out on the trail. Lets you drive out without losing all your fluids. Have not had a problem with mine. Get it from High Angle Driveline.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    that is normal, you want a little play there but not alot.
  4. 82_k5
    Oct 3, 2003
    94
    ok, thanks.
