Troubles putting tranny back in!!
Discussion in '1983-2005 S-Series models' started by 80K5, Nov 30, 2002.
  1. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Hey, today I pulled my first tranny and it was out of a 91 chevy s10 pu. When I whent to put the tranny in it seems to go in most of the way but not quite. I am not able to get the shaft to line up with the bellhousing quite right so it sticks out about an inch and a half? Basicly the tranny aint meeting up with the bellhousing. do any of you guys have any tricks to get them lined up and back together as one?
  2. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    is the Torq Convertor all the way seated???? if not it will seem like the tranny doesn't fit too hot any more??? had a problem like this b4 on a fullsize, got the torq convertor seated and it fit like a champ. hope this helps
    Ck1500 /forums/images/graemlins/ears.gif
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    use an alignment tool to align the clutch center on the crank. then get a friend to turn the output shaft to get the splines to line up. the shaft has to fit into the end of the crank and that is what you do not have lined up.
    TJ /forums/images/graemlins/truck.gif
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Sounds like you might have rested the tranny on the clutch splines and it moved on you. Realign the clutch and tryit again. Make sure the tranny is in neutral so you can have a little play by moving the rear yoke back and forth while installing it.
    Another problem could also be the pilot bushing. Did you replace it and if so is it installed straight and as far as it need to be? Is it the right size.?
    John
