Troubles with the emissions
Discussion in '1982-Present GM Diesel' started by JORGE, May 19, 2003.
  1. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    Today i,ve gone to pass the periodic Technical inspection with my 6.2 .
    The smoke test has been incorrect.It has thrown a lot of black smoke when they have accelerate it with the vehicle stoped.
    The truck throws more smoke for the right exausht than the left.
    Finally ,how the Inspection Station was almost empty,with out more people than me,they have checked the truck with other tester engine, and then the test has been correct:Smoke opacity=1.94.(I think the limit is 2.5 for NA Diesel engines.)
    But the inspector has said to me that i,ll have to repair it for the next inspection.If they woulnd,t repeat the test,it would be incorrect.
    What can i do for get more clean smoke from my 6.2?It has a lot of coal in his exhaust and air intake.
    Should to help stanadyne or wynn,s additives?
    Thanks a lot for your help.
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Im assuming there are no restrictions in the air intake ducts or filter. If not, then you may have some injectors that are getting worn and/or a few cylinders low on compression causing an inefficient burn.
  3. JORGE
    Jan 10, 2001
    213
    The engine is good.It never throws blue smoke and doesn,t eat oil between the maintenance services.The truck runs strong and fires with only touch the key.
    Until now i havent troubles with the emission test.I have to pass it each 6 months.From the last the truck has made 2000 miles or so.
    This may to be a trouble from the fuel or air sistem.Maybe some dirty inyectors or so.
    Have anyone of you BOSCH inyectors?I think mine has.
    Thanks.
