Troubleshooting heat please help
Discussion in 'The Garage' started by RootBreaker, Jan 15, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Ok so now my heat doesnt work... anyone know what wires on the back of the switch is hot? I can run a hot wire from the battery to the blower and it works.. also can take that hot wire and move to before the capacitor or whatever that is and the heat works.....
    I checked my fuses but dont see one that says heat.... anyone have any ideas what color wire should be hot?
    thanks... going wheelin Monday on a cold day and need to figure out the heat.. I can run a hot wire to a switch and just do that but want to fix it correctly...
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    From the fan speed switch:
    B/OR goes to heater res.
    BRN goes to fuse box and heater res.
    B/LBL goes to heater res.
    OR goes to back of instrument cluster
    Hope that helps :dunno:
