tru-track
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Russell Keys, May 7, 2000.
  1. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    At our club meeting this week I talked with a guy about a locker he had. He said he had a posi unit out of a Scout D-44 and it would work in mine. Does anyone know for sure? Also I read awhile back in one of the many 4-wheel mags I get that when you go to 4.56 or lower the carrier is different, something about ring gear thickness. If this is the case then If he had 3.73 and I want to go with 4.56 or lower will the locke fit?
  2. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    I would have too say call or e-mail randy's ring and pinion.THey would know all the available options and compatability probably off the top of there heads.They do make some thick ring gears to fit the smaller ratio carriers but don't know the details.
  3. kermit
    kermit Registered Member
    Apr 27, 2000
    24
    Phoenix, AZ
    3.73 is the changeover point on Dana 44's. Gear sets lower (numerically higher) than 3.73 take a different carrier, so the locker or posi unit (there's a big difference....find out for sure what it is) will not fit 4.56 gears. Check out this link for more info:
    http://www.drivetrain.com/dana44.html
    Len
    half Chevy + half Jeep = Cheep!
  4. Rockblazer
    Rockblazer 1/2 ton status
    Feb 18, 2000
    114
    South Dakota
    Uh couple of things here, first you didn't say if you have a 44 or 10 bolt. If it's a 44, then yes it will work. From experience (if you have a 10 bolt) the carrier is the same for 3.73 and lower. Ie, 4.56. Not sure about the dana. Hope this confuses you enough to seek profesional help! Ha!
    "You're right... I don't understand that Jeep thing!"
  5. Rockblazer
    Feb 18, 2000
    114
    South Dakota
    Oh yeah, sorry forgot about the locker thing. Tru trac is not a locker it is a limited slip or posi! Or like we call it out here is positively open! Seriously though, if you are using it for a front application and your wheeling consists of mostly mud or snow not rock, it will probably work ok. You can also build them posi's to make em' work a little better. A friend of mine rebuilt his with extra clutches and actually installed them backwards to get a tighter posi. Used it for years in a generation I Bronco.
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The Detroit Tru-Trac is a gear driven style posi (no clutches). I have had one the back on my Blazer for a couple of years now and really like it. No, it's not a true locker, but it seems to work better off-road than any other limited slip or posi I have seen.
  7. Rockblazer
    Feb 18, 2000
    114
    South Dakota
    You are so right 6.2! I totally brain farted! I was thinking Powr-loc. Something totally different.Duh! Thanks for correcting! Take care...
