truck axles
Discussion in 'The Garage' started by 1979jimmy350, Jun 9, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    What kind of axles were used in the early fiftys. I am looking at buying a 1951 Chevy Two wheel drive truck. The owner says it is half ton but it has eight lugs and a rear full floater. The diff is huge even bigger then a 14 bolt. What kind of axle could this be? And are they any good?
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    rear end should be an Eaton.... and the front end was made by a company called Napco, they made Factory 4wd conversions back in the 50's.
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    Are these rear axles any good? would this truck be worth buying?
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i like the rear eatons... i think there are different sizes,, i think the bigger of the two has like a 10.5 or a 11 inch ring gear.. you can use 14ff axle shafts and detroit locker, and i think you use the side gears too... somone will chime in and correct me. but yea the rear eaton is good...
  5. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    1951 eh...? how much they want?
    If you need specifics I have a shop manual for those years,
    I own a 1956 pick-up too.
    i'd love to have it 4 wheel, good luck finding a NAPCO though. You mihgt be able to retro fit something though????
    -anyone with a napco get ahold of me first! /forums/images/graemlins/wink.gif
