truck badass-ness scale
Discussion in 'The Garage' started by BranndonC, Feb 10, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok so we all have opinions on what makes a rig more badass or less badass than ours, so i propose a badass scale, for example, i'll start by saying something like:
    mogs = 10 points
    d60 = 8 points
    d44 = 5 points
    10 bolt front = 4 points
    stock 350 = 5 points
    stock 454 = 7 points
    built High hp/tq BBC = 9 points
    etc etc...
    just trying to figure a way to figure out rig greatness with a mathematical formula for laughs...
    i mean we all see rigs that are slightly less than ours and slightly better than ours and i just wanna see what people rate certian things as far as what makes a good rig /forums/images/graemlins/peace.gif
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    rear steer = 10000000000000000000000000000001 points
    4 link = 10000000000000000000000000000000 points
    both = 99999999999999999999999999999999 points
    And you even do 4 link with rear steer????
    nick
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    D44 and 10 bolt need to be worth the same
    lockers, winch, and any custom fab need to be worth serious points
    crossover and hydro assist gotta be worth something too /forums/images/graemlins/thumb.gif
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    bling should be negative points. this should not include chrome steel wheels though, as they're just as functional as any other steel wheel. if it serves no purpose, like 40 KC DayLiters across the top of the cab, its negative.
  5. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    i score a 23 on the rictor. /forums/images/graemlins/thumb.gif
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    how do you figure? there's no set scale yet?
  7. hi pinion
    Sep 25, 2003
    5,354
    i was going by the one on top,but if i can make my own scale,it would be much higher /forums/images/graemlins/grin.gif
  8. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Bull shizzy! The highest you can score on that is 19 if you run mogs and a built big block!
  9. DaHateTank
    DaHateTank Registered Member
    Jan 2, 2003
    7
    D44 and 10B should be NEGATIVE!!! yech!!
    IFS should be MORE negative. /forums/images/graemlins/tongue.gif
    dual cases, maybe 8?? Equal to D60 (Im asssuming D60 front...D60 rear ain't too impressive, IMO)
    -Marty
  10. hi pinion
    Sep 25, 2003
    5,354
    yeah,i lie,i made up my own number for my front /forums/images/graemlins/grin.gifok,ive talked enough for 4 days here,now its time to listen........ /forums/images/graemlins/thinking.gif
  11. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
  12. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    1031RRv1.0
    How does that stack up /forums/images/graemlins/dunno.gif
  13. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]I definantly disagree... /forums/images/graemlins/wink.gif
  14. Bullet
    Mar 14, 2001
    1,222
    Abilene, Texas
    What about if all your bling is in the interior? I have a billet dash, billet shaved vents and billet shaved door inserts where the stock pull straps used to be /forums/images/graemlins/tongue.gif
  15. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Your RigRater Score:
    792RRv1.0
    Your Break-Over Angle (BOA) is 27.46 degrees!
  16. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    822RRv1.0
    Your Break-Over Angle (BOA) is 23.27 degrees!
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
    Rene
  17. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    789RRv1.0
    Your Break-Over Angle (BOA) is 24.48 degrees!
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  18. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    899RRv1.0
    Your Break-Over Angle (BOA) is 25.32 degrees!
    You need to add Rockwells to your list!
  19. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    [Gregs soapbox]
    The problem with all these types of rating systems is that they rely on the "bigger is better" mentality.
    I don't necessarily agree that if 1/2 Tons are normal, then 1-Tons are better, therefore 5-Ton axles are better still..... Same goes for tires....35s -> 38s -> 42's -> 48s -> ???? Is bigger the most imporant criteria??? /forums/images/graemlins/dunno.gif
    I could theoretically build a truck with the LARGEST available part in each category (engine, axles, tires, etc).....would that make my truck badass??? I think NOT. Odds are I'd have an abomination that could never be driven on the street, and was SO specialized for one purpose that it would be bascially useless for everything else........ kinda like trying to do your daily commute in a Top Fuel dragster. /forums/images/graemlins/rolleyes.gif
    I think that "Badass" is probably more a function of how close a vehicle is to it's desired functionality. A truck that is built-to-the-hilt for crawling, but fails to provide basic comforts or safety as a street-driven truck (if that was also a criteria) has failed miserably. It's hard to feel "badass" when you can't drive it anywhere, or afford the gas in the tank....or are afraid to drive it because the tires will wear out too fast.
    To my view, "badass" is the truck that can do the kind of wheeling that the owner wants to do with a MINIMUM of compromises to creature comforts, and driveability on the street. The more places you can enjoy your truck, the more "badass" it is.....
    [/Gregs soapbox]
  20. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    795RRv1.0
    Your Break-Over Angle (BOA) is 26.10 degrees
    Not too sure what all this means but was kinda fun to put it in.
    My rig is BadAsss! there now no one needs to guess if it is or not cuz I just said it was /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
