truck boggs around 1000-1300 RPM
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yunit, Mar 24, 2002.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    This is an 87 Jimmy with a TBI setup. The truck boggs somewhere between 1000-1300RPM under load and in park or neutral. My cousin guaranteed me that it was the throttle position sensor, so i changed it and no good. What do you guys think it could be? My next step is probably to replace the MAP sensor.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Dont think its a map sensor.If the MAP is bad your engine will usually run pretty rough and the check engine light will come on.
    how long has it been since you changed the fuel filter?
    Also check to see in there are trouble codes stored in the computer
  3. shoeless
    shoeless Registered Member
    Nov 1, 2001
    99
    N/A
    don't 87's have an adjustable TPS?
  4. dyeager535
    26,979
    Your truck has a computer. Quit throwing parts at a problem, and use it! At the very least, get a service manual and rent a scanner to make sure everything is running in the correct range. (correct O2 sensor operation, TPS, etc., etc)
