Truck Bogs under Load?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by klier, Sep 4, 2000.
  1. klier
    klier Registered Member
    Jun 19, 2000
    88
    Faribault, Minnesota
    Hey!
    Of course I'm lusting to be able to spin all 4 of my 33" tires in the mud like all you guys do, but I have a problem you may be able to help me with.
    First of all, I've got an '86 Chevy Blazer - NP203 - Chevy 350 - TH350 - Edelbrock Performer Intake - Holley 600 CFM Carb - There are pics at http://kliernetwork.net/truckproject if you want a look
    But anyways, I have this lack of power whenever the truck is under load. Hell, it almost seems like the pitch of the engine changes, even at idle, after I try to tug something with it. It is enough bog that it will actually stall the engine. I was thinking it may be an improperly tuned carb, but can you guys give me a list of things to check regarding this problem?
    Thanks a lot!
    Brian Klier
    '88 Camaro 305/TH700R4
    '90 GMC S-15 4.3l/TH700R4
    '86 Chevy Blazer Hybrid Project 350/TH350/NP203
    brian@kliernetwork.net
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
  3. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Does it do it without anything hitched up to it? If not you might want to start with the Tork converter and or tranny, and or gearing at the diffs...assuming that the motor runs great with nothing attached to the K5...if you're meaning load like shoving your foot off in it than start with the timing, go to the HEI make sure its working up to specs, if all thats working, check for vaccum leaks, then go to the carb...tape a quarter to the holley throw it away, and go get a Quadrajet...and when someone finds the holley they've got a quarter[​IMG]Good Luck and I'm sure they will be others with long lists also!!![​IMG][​IMG][​IMG]And lastly if you want all 4 tires to show rooster tails better get good lockers or spool the diffs!!!!!
    <font color=blue> White Knight</font color=blue>
  4. klier
    Jun 19, 2000
    88
    Thanks for the response!
    Yeah by load I mean just making the engine work more than it would on a flat asphalt road for example. Yes, I was actually pulling a trailer in 2 foot high wet grass at the time, but i can duplicate this problem every once in a while by just speed braking too. Once the engine gets in this "mode" it is like it loses half of its power. Eventually after about 15 minutes or so it will go back to normal - kind of hard to explain. The idle will still be strange in that "mode" even with the tranny in park, so I highly doubt it's driveline related.
    Seems to run very well on of them there flat roads though, but thats not exactly what a 4x4 is for now is it? :-) I may just take your advice on the Holley if all else fails here. I only paid $50 for the thing anyways...
    Brian
  5. derek2002
    derek2002 1/2 ton status
    Aug 1, 2000
    247
    Midland, Michigan USA
    Maybe a clogged fuel filter?
    Later,
    -Derek
    1977 3/4 Ton & Blazer Project (Body Needed)
    http://www.4chevy.com
  6. White Knight
    889
    Ft Worth,Texas
    Check the fuel flow....is it electric or mechanically driven...and again toss the holley!!!![​IMG]
    <font color=blue>White Knight</font color=blue>[​IMG]
  7. klier
    Jun 19, 2000
    88
    I have a mechanical fuel pump on there.
    I spent a little time today thinking back at all the times this "strange idle" started happening, and there seems to be a few commonalities...
    1. Usually after I drive a long distance, like 3+ miles and the engine gets warm.
    2. After I shut off the engine and let it sit (heat soak), then I seem to have this strange idle problem at the next startup until that heat bleeds off.
    There is no heat shields on these exhaust manifolds, and it does get pretty warm. The spark plug wires, especially number 8, seems to be pretty hot to the touch (near the spark plug end). Is this heat somehow causing the wires to misfire causing this missing/strange idle?
    Brian
  8. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    Choke may not be operating correctly. Is it a manual choke, heat tube type, or the electric choke?????
  9. klier
    Jun 19, 2000
    88
    It's got a Holley with an electric choke. The Choke plate is fully open (vertical) every time I have looked...
    Brian
  10. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Brain- Your last post sounds really familiar to me- I had a similar problem a few years back, and it ended up being a weak diaphragm in the mechanical fuel pump. As soon as it got warm, my performance dropped, and occasionally would be really hard to start if I shut it off, ran into the store for a few minutes, and then tried to fire her up again.
    A friend suggested I eliminate the mechanical pump, so I swapped it for an electrical pump back by the tank. I haven't had a reocurrence, and I gained some power to boot!!
    I would also recommend checking the fuel filters, and something tells me you might want to check your ignition module- heat can cause those little buggers to act up, too!!Most auto parts places have a free module testing available.
  11. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    <font color=blue>What about the float level? Are you able to adjust it on your Holley, if so have you checked it? - Steve</font color=blue>
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    http://sosaman.home.texas.net/carpics.html
