Truck cab on blazer frame?
Discussion in 'The Garage' started by trollporter, May 26, 2004.
  1. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Found a 86'/forums/images/graemlins/truck.gif body in the paper and was wondering what was involved in putting that body on a 84' K5 frame. Do body mounts match? Does it matter if it's a 2wd body? I've heard that the truck body is 2" lower in the front, is that true? Now will be the best time since I'm about to start some major body work to fix the cancer on the Blazer. I think that a extra short bed would ROCK /forums/images/graemlins/peace.gif. Pics welcome.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i believe the front 4 mounts match, rad support and front cab mount. the rear cab mount you will have to modify the truck cab mount to fit the blazer frame.
  3. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    It is an easy swap just a few differences. You can pm me with ?'s if you want. Here is a post from a while back with most of the guys who have done this posting up. CLICK HERE! Hereis a pic of mine sorta.
    You can find more CLICK HERE!
  4. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    Sounds like a good idea. I plan on using a Dakota cab and a chevy step box. I won't have to cut much off the box, I will have a bit more fabing for the cab to fit. I am in the same position good frame and bad body, goodluck. Here is Backyard's truck:
    http://www.cardomain.com/id/backyardbuilt
  5. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
  6. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Heres mine. 75 cab on 76 frame. Pretty straight forward.
