truck cab on blazer frame
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by codyoffroad, Nov 24, 2002.
  1. codyoffroad
    codyoffroad Registered Member
    Aug 14, 2002
    6
    Montana
    I was woundering if anybody has put a truck cab on a blazer frame. Do you have any pictures????? Any good Ideas for the bed /forums/images/graemlins/truck.gif /forums/images/graemlins/k5.gif
  2. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    There's a few on here, Backyardbilt & Fizzlefry come to mind.
    Doc
  3. CrazyCoot
    CrazyCoot Registered Member
    Nov 24, 2002
    25
    Redding, CA
    I'm finishing mine right now. The cab bolts on. I used a 2wd cab for more floor space inside. Things are a little tighter under body now. I built a 6 1/2 foot flat bed. Anything longer than about 5 feet long will need to stretch the frame. Any other concerns....ask away!
  4. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Try doing a search.
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Frizzlefry's rig
  6. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Keep in mind that by swappin to truck cab you will have to register it as a truck, not as SUV!
    Bill
  7. doc70sub
    Oct 8, 2000
    688
    Thomasville, NC
    The only reason I'm swapping to a '74 truck cab is to avoid '79 emissions (cats, etc.) & my quarters flap like lil-birdie wings in the wind! LOL
    Doc
  8. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    They might check the frame if they suspect any swaping going on!
    Bill
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    depends on what state youre in, some places like here dotn even have inspection for light duty and passenger vehicles, do whatever you want as long as feds dont know.
    i tried to setup a 72 K5 for a 67-72 cab, but found out hard way that the 4.5" shorter the frames are than 73-up isnt a good thing, would have to have alot of body lift to get rear cab wall bottom to clear frame upward arch for rear suspension..,
  10. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    The trucks(short beds) are about 6-8" longer wheelbase than the K/5's.Could be a problem,or a blessing.....longer wheelbase good!
  11. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Shortbed is 10 inches longer than a K5 (117")
