Truck Cab Swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Calclips, Jan 31, 2002.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    What year truck cabs are interchangable with a 79 3/4 ton 4x4? Also, was the rear end in the 79 3/4 ton with a manual trans and NP205 a 14bolt ff?
  2. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    As long as you keep with a 4 wheel drive cab from 73 thru 87 you will be good. the hump on two wheel drive cabs is shorter that 4X4 cabs. You could use a 2 wheel drive cab, but you would need a body lift.
    <font color=red> It is just as much fun to build it as it is to bash it</font color=red>
  3. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    You can cut out the hump on a 2wd cab and put the hump of a 4wd cab and you don't need a body lift. I know, because I did it.
    73 3/4 ton Chevy. 383 stroker, TH350, NP 205, 14bolt FF(Detroit), Dana 44(limited Slip), 6in. lift, 36x 14.5 super swampers
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've got a 2WD cab on my K30 with TH400 and 205. Previous owner put it on after a roll over. It's tight, but it fits. I don't know if other combos fit, but mine does. However, I would prefer a cab with a bolt in tranny tunnel. Better for obvious reasons.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
