Truck Died Tonight..
Discussion in 'The Garage' started by TONYP, Dec 12, 2002.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Ok, I’m driving home from work and get off freeway. I give a little gas and she kinda sputters. I’m thinking I gave her just enough gas to get in that middle point of go and no go. So I let her roll to the red light and give her gas and nothing. I put it in park and turn her over, starts up for a sec then dies. I’m thinking gas…nope, just toped it off this morning…no oil, nope she want to run….So I’m thinking fuel pump. Try to start her again and she runs but sputters out…Fuel pump…. Tow truck driver ask what I thinks wrong, I tell him fuel pump…he has to get in and try to start it….”yep fuel pump” he says….. Thanks guy..
    So anything else you think might be wrong? And if it is the fuel pump what is the best one to install on a 72” no smog Q-Jet?
    /forums/images/graemlins/k5.gif
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    It could be a dirty fuel filter.
    A stock fuel pump should do just fine.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Fuel pump or clogged filter sounds like a likely culprit. I agree, a stock pump is fine. </font color>
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Change the fuel filter first. If no go, bolt on a new pump. My old 72 K5 had a 454. It would vapor lock when it was hot. I put an electric fuel pump in line back by the tanks. When it'd bog down, I hit the switch and it'd roar back to life /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Check and see if you have fuel at the carburetor. That is the quick way to find out if it is a fuel problem.
    Mike
  6. TONYP
    Aug 13, 2002
    2,116
    so cal
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    the fuel pump went out, got a new one and she fired right up...thanks guys
