Truck dies at full power steering lock?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pookster, Jun 26, 2003.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Any of you experience this? The engine cuts out when you have the wheel turned all the way?
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    This is a really far fetched guess, but people can correct or flame. But Maybe it has to do wiht your vaccuum, maybe lines going into your pwr steering sprung a leak? AIR unit, vacuum hoses? If theres too much pressure or not enough in the system then then ur engine might shutoff? /forums/images/graemlins/confused.gif
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Remove the PS belt and see if it still does it.
    Just a wild ass guess but I guess it would eliminate weirdness from the PS pump....
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    its definately a vacuum problem from the sound of it...take a good peak around and see what you find...
  5. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    whip out some carb cleaner, turn the wheel,& start sprayin',, you should find a leak /forums/images/graemlins/thumb.gif
  6. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I'd check for a bad/stuck pressure relief valve in the PS pump. You know the squeal pumps make when you turn full lock? That's the relief valve relieving the hydraulic pressure when it can't turn the wheels any further. Maybe yours isn't relieving? /forums/images/graemlins/grin.gif The valve is behind the big 1" nut on the back of the pump where your high pressure line connects.
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Any updates?
  8. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    Fuel filter? not getting anough power to turn the tires so the engine just stalls, just somthin to check with the TBI trucks /forums/images/graemlins/thumb.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Mine does it occasionaly. I just attribute it to having the truck angled while on a incline trying to turn around with the A/C on. /forums/images/graemlins/grin.gif
  10. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Nah, just changed the fuel filter, still does it. I think it has something to do with the idle management, im not sure where to start diagnosing. Today, the truck, just idled itself out. My mechanic says its probably the EGR, I doubt it personally.
