Truck dies when turning around corners...
Discussion in 'The Garage' started by NITRO, Jul 14, 2003.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    whenever i turn a corner, it will just die all of a sudden. no sputtering or anything...it just dies. i was thinking something electrical. i took the carb all apart and cleaned everything. it is the edelbrock 1407 carb. i got to everything but the low speed circuits on it....cuz i have no idea where exactly those are. in the manual it says to blow them out. i took out the idle tuning screws and cleaned out the holes where they go in with carb and choke cleaner. i also replaced the fuel filter and moved the fuel line away cuz i thought i might have been vapor locking. now im starting to lean towards electrical. mayb something in the steering colum itself. i have no clue n e more. give me some ideas. thanx
    NITRO
  2. Grim-Reaper
    7,385
    Atlanta
    Somebody else had the same symptoms last week and it was wigint problem down by the starter. Think he said one of the fusable links was bad.
  3. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    aight...thanx for the idea...ill check it out
    NITRO
  4. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Is your tilt column loose? My regal did this for a while. Fixed the column and it went away.
  5. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    ya it is loose. i guess ill tear into and see whats up. but its weird cuz it has always been loos but this just started. and it doesnt have a fuseable link by the starter...it was taken out when the remote solenoid was put in
    NITRO
  6. Rob 85K5
    1,487
    Pensacola, Florida
    Mine didn't start right away either.
    Only on left hand turns too, then straighten it out and turn right back on.
  7. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    how hard is it to get into there and get everything tight?? i know i need a steering wheel puller and i got one of them...so what else do i need?? is there a website somewhere that tells u everything?? if not ill just start tearing in. also, how long does it take?? thanx for n e info
    NITRO
  8. Rob 85K5
    1,487
    Pensacola, Florida
    I think there is a tech article on here. Bigburb wrote it I believe.
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  10. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    i started disassembling it, but didnt really have the time to do all of it, so i put it back together. hopefully i can get the tools and the patience and get it all tight and back together this weekend sometime. looks like a lot of work. thanx
    NITRO
  11. Grim-Reaper
    7,385
    Atlanta
    The only way it's going to be as a result of the loose steering wheel is if it's somehow binding the lock. The electrical part is down on the column by the brake peddle. All that is up at the key is the colum lock and a linkage rod that controls the switch down near the peddle on the top of the column.
    If it's a electrical problem then it's down there. I still lay odd that you problem is under the hood down where the starter wires are. Trace that harness all the way up the fire wall and meter it out.
  12. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'll talk to pops he tightened mine up a couple summers ago.
    Swing out by I got some new toys /forums/images/graemlins/thumb.gif
    I got to put one of them together though!!
  13. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    well....it only does it when i turn. thats y i dont think its the harness. and plus those links have been taken out...they were taken out when the remote solenoid was put in. i guess ill tighten it up and see what happens. how long does it take??
    NITRO
