Truck doors on a k5?
Discussion in 'The Garage' started by odoa3, Aug 2, 2005.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    Won't doors from a '75 or '76 3/4 ton swap right into into my '75 K5? I would like to make half doors with the ones from the truck. Just want to make sure before I pick them up.
    Thanks.
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yes, they will. You just need to cut them to fit the top and don't forget the support brace that's welded inside of the door where the cap goes on it (by the door lock)
  3. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Cut them to fit the top? You mean the roof, correct? You just trim the top of window frame I take it? As for the brace, wouldn't I have to cut that out when I cut the door down?
  4. stick
    stick Registered Member
    Mar 24, 2004
    76
    omaha
    you make them look like this when you cut them down to fit the older topper there is a brace under the cap that is circled in yellow
  5. stick
    Mar 24, 2004
    76
    omaha
    the yellow circe in the bottom pic. oops.
  6. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Thanks Stick! That explains it.
