Truck drives slow!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Frogg89, Mar 26, 2004.
  1. Frogg89
    Frogg89 Registered Member
    Jul 29, 2002
    85
    Southern NJ
    I just put a rebuilt 350 in my 89. It has a comp cam in it and I also put a 670 cfm Holley TBI on it. It runs good, no codes or anything like that, BUT, it is so sloooow. It was slow like this before the motor change and I thought it would improve. It has no pickup or power. I was wondering if anyone knows what could be my problem???
    Thanks, Ken
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    what kind of gear ratio are you running with those 36's?
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    put some 4:56 gears in and you will see a big increase /forums/images/graemlins/thumb.gif
  4. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    I have 4:56s in it, got that done after I lifted it!!! /forums/images/graemlins/1zhelp.gif
  5. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    Could it be some kinda sensor or something thats holding it back?? Lets put it this way , I can floor it and it picks up at the same rate as if I were just "touching the pedal"!!!
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    When was the last time you change the fuel filter??
    Couldnt believe the difference in mine after the change. Could be a clogged fuel pump screen too. Sometimes it will set a Lean code.
  7. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    No, I havent tried the fuel filter. I assumed that a bad filter would give me hesitation or stalling probs, I just have no pickup!! But, I did get a filter a while back, I guess Ill throw it on tommorrow!! It wont hurt!!
    Thanks, Ken /forums/images/graemlins/k5.gif
  8. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Check how much oil is in it. Sounds dumb but I was with one of my buddies and it wouldnt go very fast. I told him to pull over and I checked the oil. He must have only lad like 1 or 2 quarts in it. We put some oil inn and it started working better.
    Nick
  9. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Could maybe be a plugged catalytic convertor too...that'll kill power!
    Rene
  10. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Hmmm, double post....
    You must really want this problem fixed /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  11. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    I do Its driving me nuts!!!!
  12. 88Silverado
    Mar 13, 2003
    2,664
    When my filter was plugged, it just got a little harder to start but no hesitation or stumble, just no power. Got so bad that if I floored it, the RPM's wouldnt get high enough for the governer to allow the trans to shift gears. That was about the point the computer started to flag a Lean condition, but only at WOT. Was a HUGH dofference when I changed it. TBI's need pressure to work properly. Again, could be a plugged filter on the fuel pump in the tank too. There are adaptor kits so you can put an in-line pressure guage and take readings. Just a thought /forums/images/graemlins/peace.gif
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cat converter being plugged is a good palce to start, have seen it happen several times and cause weak engine power
  14. husurddy
    husurddy 1/2 ton status
    Jul 28, 2001
    108
    Snow Hill, Maryland, go east \'till you hit water
    I just put in a new fresh engine with a towing cam and found that the timing had to be advanced quite a bit. Runs great and the best part is more power AND better MPG! /forums/images/graemlins/woot.gif
  15. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    I did try the fuel filter today and it wasnt it!!
    Where did you set your timing?? I just want to see if I got mine right!!
    Thanks,Ken
  16. husurddy
    Jul 28, 2001
    108
    To be honest, I can't remember. I was advancing it a lil' bit at at time, trying to stay away from spark nock and.....my inductor wire for the timing light burned up on my header. /forums/images/graemlins/eek.gif Don't hold me to this but 12 degrees rings a bell. I have been really happy with the results and my exhaust doesn't smell rich anymore. I'll have to pick up another light this weekend and check.
  17. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    u sure its running right on all cylinders and has the right amount of compression? just an idea i dunno .. /forums/images/graemlins/dunno.gif
  18. 84blazerwhoopee
    84blazerwhoopee Registered Member
    Feb 13, 2004
    36
    Minneapolis, MN
    Along these thoughts, I saw a mechanic mark with some type of chalk real close to each exhaust port on the manifold and then ran the engine for a few minutes. he then went back to look at the marks to see which was not discolored. I never found out what special type of chalk he used, if any, but it sure seemed like a smart idea at the time.
    Randy
  19. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    That would be a temp stick...at a certain temperature it goes from chalky to melted looking. I guess you could tell if any cylinders were running lean that way. /forums/images/graemlins/dunno.gif
    We use many different temp sticks to guage the amount of pre-heat before welding.
    Rene
  20. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Which cam did you choose?
