Truck has no power!!!
Discussion in 'The Garage' started by Frogg89, Mar 26, 2004.
  1. Frogg89
    Frogg89 Registered Member
    Jul 29, 2002
    85
    Southern NJ
    I posted this in another forum but I figured Id try this one too!! I replaced my 350 with a rebuilt one with a comp cam and I put a new 670 cfm Holley TBI on it too, assuming Id get some more power compared to the old tired stock motor!! The prob is its the same as before, My truck accelerates VERY Slowly!!! I could put the gas to the floor and it picks up like Im gently touching the pedal!! Does anyone know if it could be one of those computer TBI sensors that is holding it back?? It runs good with no codes, just doesnt have the power it should!! /forums/images/graemlins/1zhelp.gif
    Thanks, ken
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Fuel Filter?????????
  3. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    My 350 has a bad cam in it right now and gasmileage sucks balls and the power sucks, i'm ordering a new one next week and installing it next weekend, was the cam broken in properly? Probably not the issue, but just an idea.
  4. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    Im still breaking the motor in but I should have some kinda power. Its doing the exact same thing that it did before this motor. Its got to be something that I havent replaced yet!!
    Thanks,Ken
  5. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    If you had a bad cam you would hear it anyway. I would suspect it has to do with a sensor or something being bad? Or maybe clogged exhaust or something? Do you have cats?
  6. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    Yeah I have cats. Dont they get like cherry red when they clog up?
    Thanks, Ken
  7. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    They won't always get red when clogged, maybe only if you've run the engine real hard.
  8. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Is it a gear issue???? Maybe you are expecting it to do to much with the 36" tires. If you put in to big of a cam, and have the wrong gears, it will perform miserably....
  9. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    I have 4:56s in it.Its not a gear issue
  10. 1badv10
    1badv10 Registered Member
    Feb 26, 2004
    74
    new york
    like someone said above the fuel filter should be your starting point, how long has it been since replaced? my truck actually had more power at 1/4 throttle then it did at full.. drove me nuts /forums/images/graemlins/doah.gif, had no idleing or stalling problems.. for 5 bucks at walmart you save can save your sanityhope this helps /forums/images/graemlins/thumb.gif
  11. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Are you using the same h/balancer as your old motor? I spun the outer ring on mine once and when I rebuilt the motor I couldn't time it as the t/marks were in the wrong place! It ran but it was horrible and got hot quick.
  12. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    My truck was a dog with fleas and ticks till I got a new cat /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  13. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    When I put on my new exhaust I looked into the cat and noticed it was melted and I could see like two very small holes through it. After I put on the headers even with a bad cam it felt like a new damn motor lol. But it was all the work of a holley carb that sunk the floats and dumps a lot of fuel in, i'm not running a Q-Jet and its wonderful! Except for the shitty power from the cam of course. 3.42s and 33's don't help either. But if its not throwing any codes then maybe it could be fuel filter or clogged exhaust?
  14. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    This sounds like mine but I changed the filter today and that wasnt it /forums/images/graemlins/1zhelp.gif
    Ken
  15. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    have you tried adjusting your timing to find the best setting for your truck? Never hurts.
  16. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Hey the fuel filter worked for me too.
  17. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    Thats something Im still messing with!! I think I got it now!! It seems really advanced but I heard it has to be with a performance cam.
    Thanks, Ken
  18. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    If you have an 89, you need to disconnect the brown & Black wire for the timing to read it. If you dont, the computer takes hold of the advance.
    Still can be a plugged fuel pump filter. Do you have any way of reading the pressure??
  19. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    The brown and black wire??? Ive never had to do the timing since Ive had this truck!! Which wire is this??
  20. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    It is right out of the fuse block on the engine side of the firewall. There is a quick connect plug. I over looked mine several times before I found it.
